Post
by bobster » Tue Mar 11, 2014 7:43 pm
Try Screwing the mixture screws out another1/4 to 1/2 turn and see if that helps. Remove the diaphragm springs and stretch them all so they are 20mm longer than they were but make sure they are all the same length! Did you check the diaphragms for holes???
When bike is running squirt some WD490 around the inlet rubbers, if they are sucking air the revs will rise! indidcating there is an air leak.
BALANCE THE CARBS !!!!!
G0FHM
Post
by G0FHM » Tue Mar 11, 2014 9:23 pm
Well, after a bit of tinkering and twiddling, this is the end result:
http://youtu.be/SQmTe730MaY" onclick="window.open(this.href);return false;
I just need to sort the exhaust blow out (one of the downpipes isn't fully in the hole), and I can get the carbs balanced.
Sounding a bit better!
J
- Committee Member
- Has thanked: 80 times
- Been thanked: 72 times
Post
by sparki » Tue Mar 11, 2014 11:42 pm
Carbtune do good gauges... Lil bar thing that goes up n down opposed to stoopid dials
- Has thanked: 120 times
- Been thanked: 257 times
Post
by Kryten » Wed Mar 12, 2014 10:50 am
Does anyone read "The Pride"?
