big bore
big bore
Post by johnr » Mon Oct 20, 2014 8:13 pm
just out of interest, has anyone ever thought of using kat 1000 pistons to do a big bore on a pop up? quite randomly, ive got one of each piston in my hand. the kat 1000 is a couple of mm bigger in diamiter than the 750, but the height top to bottom of both pistons is the same, the deck height from the gudgeon pin to top surface is identical and the gudgeon pin is the same diamiter. so i reccon a modest overbore on a 750 barrel would get the 1000 pistons in. just thought id mention it.......
overbomber
Re: big bore
Post by overbomber » Mon Oct 20, 2014 8:58 pm
Did TTS not do an 840 kit years ago? Probably like hens teeth nowadays.
Might be worth risking an old set of barrels on trying it out and sounds like a reasonably feasible idea. Sounds like you think it would be doable.
KOC 396
Nordwest Pilot
S3 Flip-up
ZL400SE Eliminator
Re: big bore
Post by johnr » Mon Oct 20, 2014 9:09 pm
im more wondering, considering how scarce 1000 pistons are, if you could get a 750 big boore kit into 1000 barrels to replace stock pistons.
dave309
Re: big bore
Post by dave309 » Mon Oct 20, 2014 9:30 pm
mate of mine did it a few years ago cant remember any problems with them
harriskat
Re: big bore
Post by harriskat » Tue Oct 21, 2014 7:43 pm
oooooooooo more power???????
Re: big bore
Post by johnr » Tue Oct 21, 2014 8:35 pm
i imagine so.
Katgeezer
Has thanked: 6 times
Been thanked: 8 times
Re: big bore
Post by Katgeezer » Wed Oct 22, 2014 4:22 pm
750 big bore kits are very hard to find as well John but I imagine probably slightly more available than 1000 pistons......
I was going to try and drop the liners out of a 750 block and put 1100's in. Not sure if that's possible.
It also just so happens I have a wiseco big bore kit for a 750 on the shelf.........
Maybe I should get some measuring sticks out.
harriskat
Re: big bore
Post by harriskat » Wed Oct 22, 2014 7:06 pm
Why do other people have all these shiny bits????!!!!!
Re: big bore
Post by bobster » Wed Oct 22, 2014 7:09 pm
Because we Kat owners are a bunch of HOARDERS.............some worse than others! ;-)
harriskat
Re: big bore
Post by harriskat » Thu Oct 23, 2014 9:15 am
Very true that. And much older may I add.
