choke
spondonchris
Has thanked: 18 times
Been thanked: 18 times
Re: choke
Post by spondonchris » Fri Oct 24, 2014 8:28 pm
Well if John does not know what they are - I'm stuffed! FBJ also said similar. They are so bloomin corroded that I may be better getting a standard set any way especially if these are the wrong ones
KOC397
Re: choke
Post by Uncle Bob » Sat Oct 25, 2014 8:04 pm
I had to do a double take when I saw the pics of your 400 when you bought it, what was the choke knob on the bike? it looked like it came off a 1970's gas cooker, i'm glad you're getting the correct parts, I found b and b motorcycles in Lincoln really useful when getting parts for my 250 kat.
:) Well spotted by you. It did look like that, though it looks like someone went to the trouble to turn up a metal one and some custom brass plate on the back. Not sure if that was when it was in Japan or a UK person thinking that getting the part here would be difficult (without checking). Must have taken some time (or maybe it was a cooker knob!)
I'd found that mostly the Suzuki parts are roughly the same price from where ever (though discountsuzukispares are a bit cheaper generally), but I got those from St Neots Suzuki mainly as they also had some NOS GT200 parts I needed, so I thought I would get it all posted at the same time. I'll remember B&B though.
Re: choke
Post by callyboy » Sun Oct 26, 2014 4:41 pm
http://www.ebay.co.uk/itm/suzuki-GSX110 ... 20eeae57dc" onclick="window.open(this.href);return false;
spondonchris
Re: choke
Post by spondonchris » Sun Oct 26, 2014 9:53 pm
Thanks Pete, think they should be 34mm for the Kat 1100. I think I will keep working on this set for now unless a cheap set comes up :)
KOC397
Has thanked: 136 times
Re: choke
Post by Nicky Dodds » Sun Oct 26, 2014 10:03 pm
Sure i read somewhere 36's were a good mod to do...
Re: choke
Post by Uncle Bob » Mon Oct 27, 2014 4:38 pm
I was bored and like a challenge. I thought I would try and work out what your carbs are from. As the choke lever looks original I had a Google and I think the closest I could find were from a 1980 XS1100G. Based on this:
OK this is from a XS750 (triple) but I'm sure the same was on the 1100G for '80.
http://www.ebay.co.uk/itm/CARBURETOR-CH ... 58b43e6a71
Carbs exploded diagram from CMSNL
http://www.cmsnl.com/yamaha-xs1100g-198 ... ml#results
Lastly an image of the side of a XS1100 (best I could find) showing the mechanism.
http://i900.photobucket.com/albums/ac20 ... G_0469.jpg
They might be off something else, but must be about that era. Using CMSNL the next year, the lever looks slightly different.
What do you think?
spondonchris
Re: choke
Post by spondonchris » Mon Oct 27, 2014 5:57 pm
Good man Rob! I think that is the lever alright. Not sure about the carbs as I cant quite make out all the detail. Will dig a bit deeper now. thanks again for taking the time to look
:D :D :D
KOC397
Re: choke
Post by Uncle Bob » Mon Oct 27, 2014 6:57 pm
No probs. Be interesting to see what all the jet sizes are in those carbs. Is yours a 750 or 1100 - can't remember and was your SD an import?
spondonchris
Re: choke
Post by spondonchris » Mon Oct 27, 2014 8:21 pm
Rob, its an 1100 SD and yes it is an import. I have done a bit of gooloing since you put the XS info up and they do look very similar. The XS1100 had BS34 Mikuni carbs, so maybe someone in the past has put a set on. There was no sidepanels with the bike, so no Kat choke lever. It was also running K&N filters. I am in the process of stripping and cleaning them to see if they are salvageable, so I'll let you know re jet sizes. So far I have only managed to unseize the butterflies and 2 of the 4 slides! Will get there eventually :roll:
KOC397
spondonchris
Re: choke
Post by spondonchris » Wed Oct 29, 2014 10:00 pm
Got 3 slides free now, stuck with the 4th. Managed to dig a jet out of the filth - 152.5 main.
KOC397
