1100 clutch cover help
Hello bought a used clutch cover was told its from a 1100 Katana only problem it does not fit could it be off a 750 bike it has the numbers 454 stamped in the back.
As you can see with the gasket fitted all the holes line up but its wider at the top left of the picture.
- Attachments
clutch cover.jpeg- (54.85 KiB) Downloaded 81 times
- sparki
- Committee Member
- Has thanked: 80 times
- Been thanked: 72 times
Re: 1100 clutch cover help
gasket is like that on all of em
you saying the cover doesn't fit or you're unsure if the gasket doesn't fit?
- Has thanked: 120 times
- Been thanked: 257 times
There is a thread on here some where that was posted by some one with exactly the same problem. IIRC the conclusion is that the 750 and 1100 are different
Doh missed off a zero
- KeKat
- Has thanked: 3 times
- Been thanked: 44 times
I almost sure that is a 750 katana cover part no: 11340-45400
Keith
Keith
Keith KOC 355
1982 Suzuki GSX1000SZ
1991 Ducati 900SS
1996 Kawasaki ZZR600
2003 Transalp
2004 MV Agusta brutale F4
2003 Cagiva xtra raptor 1000
2012 Triumph Tiger 800
2019 Suzuki GSX-S 1000S
1991 Ducati 900SS
2003 Transalp
I have another clutch cover on the way am hope full that the new one is going to fit !!!
