GSX1100SD rocker cover gasket
Re: GSX1100SD rocker cover gasket
Post by johnr » Mon Jan 29, 2018 10:39 pm
if its only 16 bolt, then its likely to be an es/pop up type engine.
Been thanked: 714 times
Post by fossie » Mon Jan 29, 2018 10:48 pm
The pop up is a rubber jobbie.
Wemoto will supply Athena even if you want a vesrah which is better , it depends what's in stock.
Has thanked: 118 times
Post by Kryten » Mon Jan 29, 2018 10:53 pm
The Cometic gasket does not fully encircle the 4 bolts at either end of the cover that are adjacent to the spark plug “slots”. If that makes sense
