32mm Mik slide choke not working
Been thanked: 198 times
Re: 32mm Mik slide choke not working
Post by Pedda » Wed Apr 27, 2011 11:45 pm
Hmh, saw that arm-over-stacks-technique at HRC racers with de-activated choke. I take it the bike behaved back in the days, or is that carb recently aquired?
Post by johnr » Thu Apr 28, 2011 12:37 am
have you re-jetted it for running without filters? have you checked the compression on the engine? running without filters shortens engine life considerably. if your compression is low then its going to be a struggle to start.
Post by bobster » Thu Apr 28, 2011 6:44 am
Mine really struggles to run , let alone start without having the rear airbox fitted.
So if you are trying to start on the standard 95# jets and no airbox you'll struggle!
Post by johnr » Fri Apr 29, 2011 10:36 am
when you took the carbs off, did you stuff rags down the inlets, did you remove them???
