Rear Brake line mounting rubbers GSX400SSN
Post by Uncle Bob » Fri Jun 08, 2018 11:10 am
I have changed the rear brake line to a braided one, but am missing 1 of the rubbers that help it clip to the swingarm.
These aren't a Suzuki part number as they come with the brake line itself.
Anyone have one or know other bikes that might have them as I could possibly look for a secondhand line on Ebay with one attached to. They are flat one side that goes against the swingarm.
Marked in Yellow on the parts image below.
Has thanked: 80 times
Been thanked: 72 times
Re: Rear Brake line mounting rubbers GSX400SSN
Post by sparki » Mon Jun 11, 2018 8:44 pm
call venhill or hel as they use the same on their braided lines... maybe they'd sell/send you one?
KOCUK - 241
Post by Uncle Bob » Tue Jun 12, 2018 10:22 am
Blix wrote:Got this if it’s any use, obviously it’s been cut but that could be glued & hidden.
Thanks for looking Blix.
That looks quite a bit different but could be cut around I guess. If I can't get the same though, I'll probably use some old inner tube I have, cut and wrapped around it.
Post by Uncle Bob » Tue Jun 12, 2018 10:25 am
sparki wrote:call venhill or hel as they use the same on their braided lines... maybe they'd sell/send you one?
It was a Hel line I replaced it with, but it only had one (I think it was 1 or none) on it. I'll go for some old inner-tube wrapped around it probably.
Post by Uncle Bob » Tue Jun 19, 2018 8:18 am
Having a tidy up in the garage and found some rubber pipe with thick 3mm walls, that fitted the job perfectly, once cut to size.
