Bits n pieces are a forming
Berti44
Has thanked: 5 times
Been thanked: 21 times
Post by Berti44 » Sun Sep 23, 2018 6:24 pm
Owned for 2 years and the rebuild now begins.
Berti44
Re: Bits n pieces are a forming
Post by Berti44 » Sun Sep 23, 2018 6:26 pm
Berti44
Post by Berti44 » Sun Sep 23, 2018 6:27 pm
Berti44
Post by Berti44 » Sun Sep 23, 2018 6:29 pm
Berti44
Post by Berti44 » Sun Sep 23, 2018 6:33 pm
New stem taper roller bearings fitted.
Berti44
Post by Berti44 » Sun Sep 23, 2018 6:39 pm
Now to rebuild forks. I’ll
Nito
Post by Nito » Fri Sep 28, 2018 3:17 pm
Great to see the frame like that, looks like you're doing a cracking job of restoring that.
Nice to see the Abba Skylift working on it, I just recently bought a skylift (June!) but haven't got around to trying the Katana on it yet so nice to know it's compatible!
I doff my hat to you :)
Has thanked: 123 times
Been thanked: 258 times
Post by Kryten » Fri Sep 28, 2018 3:42 pm
Nice one.
Don't forget to fit the airbox before the engine....
Berti44
Post by Berti44 » Fri May 15, 2020 4:02 pm
Thanks Kryten for the tip about the airbox invaluable 👍👍
My tip to other folk is to make sure you put the rear brake shaft in/on before fitting the swing arm. Yep my bad 🤦‍♂️
Berti44
Post by Berti44 » Fri May 15, 2020 4:09 pm
Lockdown progress is steady: this photo was taken before I had to remove the swing arm again. :cry:
