I'm Stumped! Shorter front forks on 1100 help required
- Has thanked: 638 times
- Been thanked: 243 times
The Swiss Katana is a right pain for me to get on the centre stand, which I had mentioned before. After investigation and comparison to my other 1100 it was due to a slightly smaller rear tyre profile and the front forks appearing to be about 2cm shorter.
Sparki sent me an image of a mod that normally achieves this: So I have finally taken the frontend off today and stripped down but for the life of me I cannot see why they are about 2cm shorter. I had a spare (knackered) set of 1100 forks which I stripped for comparison. I have taken some images. Can anyone tell me how the Swiss Kat ones are 2cm shorter when inside they look the same - see images below:
Ok the sliders are the same so I have just shown the top here (Swiss top, Spare 1100 below). Clearly you can see the Swiss ones are shorter. Here are the damper rods as removed (Swiss top, Spare 1100 below) - look the same and no spacer as Sparki's image would suggest there should be. Here are the Stanchions as well (Swiss top, Spare 1100 below) which are identical. Forks tops, top spacer and springs were also the same.
I cannot for the life of me see why the Swiss ones are about 2cm shorter (top of slider to top of stanchion).
Can any see what I have missed?
Re: I'm Stumped! Shorter front forks on 1100 help required
might be in the actual fork lower leg itself. possibly from a model with a different size front wheel, is it an sd model? cos they came with either a 16 or a 19 inch wheel.
Could someone with an 1000, 1100 or 750 and a standard front end measure the distance from the top of the slider to the top of the fork tube for me. Preferably while the front wheel off the ground if you can get someone to sit on the back!
I have a feeling some user error may be involved and that measurement would help me confirm it.
- Has thanked: 4 times
- Been thanked: 61 times
i have a set lying here that i'm fairly certain are GSX1100 and measure 38.5cm (approx 15") from the top of the outer fork leg casting to the top of the chrome tube
Cheers Stockcar. On one of my 1100's it's about 46 (ish) cm and the other they are 43.5cm, so that confuses me a tad unless they are not 1100 Katana.
I wanted to see what another 1100 Katana (though the 750S1 and 1000 would be the same) is. I suspect (hoping) they will be the nearer the 43.5cm, and the 46cm ones are the ones that, shall we say, have the user error! I would know I have the correct parts then. If someone else has 38.5cm like you then I have an issue on both bikes
Hence it would be handy for another measurement from someone else. Thanks UB
Those must be odd ball ones i have at work, been out to the garage and measured the Kat and they are 43.5cm so match what you have there
- Has thanked: 118 times
- Been thanked: 256 times
Hi Bob.
I have a couple of spare sets of forks in the shed.
One set is a Kat set and the others are off an 1100E. The non Kat forks are shorter and have an odd damper adjustment on the lowers.
Typically I have just started my shift up in Sunny/Soggy Lincs.
If you are still scratching your head when I’m back I will do some measuring for you.
I can measure my forks if it helps?
Obviously they are attached to the bike but if you want an external measurement I can do it.
If 1 more person could that would be good, just to confirm the 43.5cm Stockcar gave me. External and on bike is how I did one set of mine, though I did jack up under engine to push it on to back wheel to get rid of the sag on the front (I suspect these are the ones that are wrong as they measured about 46cm!).
