How to fill oil on front fork 1983 gs650 katana
Geiros
Has thanked: 8 times
Been thanked: 2 times
Post by Geiros » Fri Apr 12, 2019 2:49 pm
Hi. Does anyone know how i can fil oil on front forks for this bike? :?:
Geiros
Re: How to fill oil on front fork 1983 gs650 katana
Post by Geiros » Fri Apr 12, 2019 5:26 pm
It has no bolt/cap on the top of each fork. :roll:
Geiros
Post by Geiros » Fri Apr 12, 2019 7:05 pm
Thanks a lot. I have to check again.
Has thanked: 185 times
Been thanked: 734 times
Post by fossie » Fri Apr 12, 2019 7:55 pm
You have a black rubber top, pop that off, under that is a 19 MM cap , .makes sure you have the adjuster in the middle wound out when putting it back on, it's just easier.
As for filling , make sure that you have emptied them both and flushed them , there will be residue of condensation and grime in them, which will alter the amount , so you won't get them both the same.
Has thanked: 658 times
Been thanked: 249 times
Post by Uncle Bob » Fri Apr 12, 2019 8:50 pm
There could be rubber caps on the top. Here's the strip down and rebuild pages from the OEM Suzuki manual.
Oil is given as a capacity but is normally fine tuned via the air gap level but as Page 59 says you need to "When adjusting oil level, remove the fork spring and compress the inner tube fully" (see PDF).
GS650G Front Fork Servicing (Web).pdf
(578.57 KiB) Downloaded 559 times
Geiros
Post by Geiros » Sat Apr 13, 2019 9:14 am
Uncle Bob wrote:There could be rubber caps on the top. Here's the strip down and rebuild pages from the OEM Suzuki manual.
I have this book. And the fork is different on katana. It is no nut under the black plastic cap at the top.
Geiros
Post by Geiros » Sat Apr 13, 2019 9:15 am
fossie wrote:You have a black rubber top, pop that off, under that is a 19 MM cap , .makes sure you have the adjuster in the middle wound out when putting it back on, it's just easier.
Thanks for replay. It no 19 mm cap under the rubber top :roll:
Geiros
Post by Geiros » Sat Apr 13, 2019 9:19 am
Top front fork
Top front fork
Cafe racer build
Cafe racer build
Post by fossie » Sat Apr 13, 2019 9:45 am
Not sure what these forks are off , they are from a 1983 Suzuki GSX , but the top cap is from an earlier model, but if you undo the clamp next to the top of the fork top, it looks like a cover cap which just prises off. As for amount of oil well that'll be a guesstimating exercise, as like said may not be 650 forks, but the top adjuster is changed.
Post by johnr » Sat Apr 13, 2019 10:19 am
to be honest, id strip them and change the seals whilst you are at it. youre going to need to take the forks off to drain the fork oil anyhow, so for the cost of a set of fork seals (10 to 15 quid) you may as well do them too. the forks tend to be neglected so its likely that the oil in there is pretty grim, as such its best to seperate them, clean them out to remove any water thats got in and any crud thats accumulated, then pop the new seals in and rebuild. youd be pretty miffed if you swapped the oil and the seals went one day, so for the extra few quid, do it right.
