The headlight on the club bike has popped up and stayed up? Is there a separate fuse for the motor or is it likely there’s a wire come loose?
It was working perfectly until after the MOT
Pop up headlight
Pop up headlight
- Has thanked: 644 times
- Been thanked: 247 times
Re: Pop up headlight
I can see why Fossie lent you Poppy now, it'll come back all fixed
Actually that seems like a great idea, would like to borrow my TZR250 (it's working fine, honest guv)!
Don't worry about it, it will sort itself out .....they all do that from time to time.
There is a red knurled knob under the fairing on the motor , with the ignition off you can wind it down....if you go to far it will go back up.
There was f.....all wrong with it before if went on holiday and it got polished!!
fossie wrote:There was f.....all wrong with Poppy before if went on holiday and she got polished!!
