Ok. Try linking the wire from the loom to the pressure switch down to earth, either the engine case or the negative terminal of the battery, with the ignition on.
If that lights up the lamp then you can check resistance from the pressure switch terminal to crankcase and again to the battery negative terminal.
Would be worth checking the resistance or continuity between the crankcase and the battery negative terminal as well.
Chasing the smoke
- Has thanked: 119 times
- Been thanked: 257 times
Re: Chasing the smoke
Good stuff.
Have you fired it up yet?
You'll have a whole weekend to getting running right for the Scottish Camping weekend
Looking good.
I see you didn't park it with the "other" bikes!
Blix wrote:I parked it in the crosshatched area with the words “Motorcycles Only” written on it.Kryten wrote:Looking good.![]()
I see you didn't park it with the "other" bikes!![]()
The other feckin eedjits are parked in the pushbike sheds![]()
Looking good Mick, that blue really sets the whole bike off.
