Fossies 250 Kat
geekay
Has thanked: 13 times
Been thanked: 81 times
Re: Fossies 250 Kat
Post by geekay » Sat Sep 19, 2020 11:43 am
so.........................
the throttles would open fully, but wouldn't return once there.
Perhaps that was asking too much of this "return" spring...........
now sorted with the fitment of the correct spring.
Then the top coolant hose split. Replaced that.
Now the genny cover gasket is leaking.
Little bugger's putting up a fight :D
Suzuki GS650G Katana x 2
Suzuki TDRGV 250
Suzuki K11P
Triumph T575 Steam Triple
Kram-It RV250 Enduro
Moto Cati V70 Monzta
Re: Fossies 250 Kat
Post by fossie » Sat Sep 19, 2020 6:23 pm
I came across the original dating certificate and old MOT certificates , do you want them Gary.?
geekay
Re: Fossies 250 Kat
Post by geekay » Sun Sep 20, 2020 7:50 am
yes please - I will send you my address via pm.
Thanks.
Suzuki TDRGV 250
Suzuki K11P
geekay
Re: Fossies 250 Kat
Post by geekay » Tue Oct 27, 2020 5:38 pm
The little Kat is still sulking and refusing to play ball.
Now awaiting a full carb refurb kit to arrive from Thailand.
Oh - and thanks for the old MOT's / dating cert Fossie.
Suzuki TDRGV 250
Suzuki K11P
Re: Fossies 250 Kat
Post by johnr » Sat Oct 31, 2020 2:21 pm
them carbs had a full set of o rings in them and literally a half day in the fizzy bath. i hate these bloody things.
Re: Fossies 250 Kat
Post by fossie » Sat Oct 31, 2020 6:00 pm
Yep a full set of o rings from Thailand . :roll:
Re: Fossies 250 Kat
Post by Smallkat » Tue Nov 24, 2020 3:26 pm
Mmm.. it's my problem now!
Re: Fossies 250 Kat
Post by pookie » Tue Nov 24, 2020 5:23 pm
Stick with it, I've owned mine over 6 years now and after initial carb / fuelling problems (worst one was a hairline split in the vacuum pipe that couldn't be seen, just sorted by trial and error) but there's no substitute for the first time you hit over 15000 rpm, it sounds like one of Mike Hailwoods racing 250s from the 1960's :D P.s seems that this bikes already had the viton o-rings fitted in the carbs which is a great idea, and when you do get it up and running use super unleaded fuel only, it seems to make a big difference
Re: Fossies 250 Kat
Post by Smallkat » Tue Nov 24, 2020 6:56 pm
I am going to go through all the hoses, just in case.
First job is to get the starter cable mechanism back on and working.
When you say super unleaded, I normally use Shell V Power, is that what you use?
Also, should the fuel tap be so close to the tank?
[image]
[/image]
The lever is jammed and I don't want to force it, so I will probably have to get a new tap anyway.
GSF34058
Has thanked: 32 times
Been thanked: 60 times
Re: Fossies 250 Kat
Post by GSF34058 » Tue Nov 24, 2020 8:02 pm
The tap looks the same as the one on my 1,000. That is also very close to the tank and difficult to get off reserve with thick winter gloves on. To get around this problem I try to fill up before going onto reserve.
It also gets quite tight once in a while, but it's easy to take apart, clean up and put back together. I use a very thin smear of silicone grease on the tapered central part. This seems to keep it free for a while, until it needs doing again: perhaps once a year. I don't think the silicone contaminates the petrol.
David
