Leaky brake caliper
Re: Leaky brake caliper
Post by PaulD » Mon Mar 29, 2021 5:13 pm
Well that's the panic over! I used the large syringe up the bottom (ooer missus) and managed to get the air out. Brakes are as good as ever (Shite lol) just need to sort the mounting bracket now which hopefully Jim Kryten has got for me. Looking forward to some summer rides out now.
Post by Lexdba » Mon Mar 29, 2021 5:31 pm
Glad you had some syringe fun today Fwend!
Has thanked: 123 times
Been thanked: 258 times
Post by Kryten » Mon Mar 29, 2021 5:52 pm
Just been reading your post regarding bubbles. I have found when using the vac pump that if there is a bit of play in the bleed nipples then the pump will draw air down the threads and it appears that the system is full of air.
I have had to put a couple of wraps of PTFE tape on the Speed Trips nipples :shock: :lol: :lol:
Post by PaulD » Mon Mar 29, 2021 7:16 pm
Yep I think that was the problem Jim, although I did wrap my nipples with ptfe fnarr fnarr :shock: it didn't make much difference.
The old giant syringe up the bottom made all the difference :lol:
Post by Kryten » Mon Mar 29, 2021 10:06 pm
:shock: :lol: :lol:
Post by pookie » Tue Mar 30, 2021 5:59 pm
Bit off topic, but for anyone who grew up in the seventies, why did the readers wives in mags like razzle have electrical tape over their nipples? and blindfolds?
Post by PaulD » Tue Mar 30, 2021 7:20 pm
Blindfolds :lol: :lol: :lol:
Post by Smallkat » Tue Mar 30, 2021 9:19 pm
weren't the blindfolds so you didn't recognise the woman next door?
I don't remember tape over the nipples, but I do have a Japanese jazz mag that has the privates censored! A souvenir from my visit to Tokyo.
Post by PaulD » Wed Mar 31, 2021 3:49 pm
Well thanks to Jim (Kryton) I've got a caliper bracket. Unfortunately Beelzebitch refused point blank to wear it until it was cleaned and painted :lol: I set to this morning, bead blasted and give it a coat of gloss black. Just give it a second coat so I'll fit it tomorrow.
Thanks Jim your a star 8-) you
Post by Kryten » Wed Mar 31, 2021 4:18 pm
I knew you'd get it sorted. I did check threads and they were good.
If you think that was tatty then you should see the master cylinder that I have just off loaded to a North Norfolk club member.
