Katana clutch problem
Has thanked: 623 times
Been thanked: 233 times
Re: Katana clutch problem
Post by Uncle Bob » Mon May 17, 2021 8:15 pm
Mac13 wrote:
Mon May 17, 2021 7:54 pm
I have just been messaging John Martin on FB. He really nice bloke and has suggested things I need to check.
Yep, he is a good bloke.
Seeing you have had this issue from when you got the bike, the parts John points out need to be checked.
I have 2 parts lists for the 1100 (and early version and later with revised parts as well) which show the clutch differently depending on the engine number:
This is the earlier parts list with only upto engine number 158879 parts shown
and this is the later parts list that shows both options - up to engine number 158879 and after.
In the second you can see part 3 varies depending on which engine you have and that was John's issue - he had the wrong one in for his engine number. You can also see that the later engine number needs shims (item 4) that need to be calculated as well.
Reading your initial post it is possible in a rebuild someone has mixed and matched the clutch parts and hence why you have this issue. I hope so as then you are on the road to having it fixed.
The test (I think) for if it is that, is take out the fibre and steel clutch plates and can you turn the crank and basket without centre turning? If not it must be those parts. If you can, well check them anyway!
Mac13
Been thanked: 7 times
Post by Mac13 » Tue May 18, 2021 5:58 pm
Hi UB,
My engine number is GS10X-100617. The bike is a GSX1000SZ.
Stripped the clutch (again) today, I hope I can get it sorted, not be a good start to ownership.
Been thanked: 77 times
Post by Lexdba » Tue May 18, 2021 9:43 pm
Don't worry, when you get it sorted it will cause you a grin from ear to ear. Nothing beats a Kat at WOT!
Mac13
Post by Mac13 » Wed May 19, 2021 8:49 am
Thank you!
Post by PaulD » Wed May 19, 2021 9:12 pm
Apart from a Kawa Z1300 😋
Post by Lexdba » Wed May 19, 2021 9:16 pm
Sure, shame you have to be Ray Charles to actually like one :shock:
Post by Smallkat » Thu May 20, 2021 12:21 am
A 250 Kat especially.
Mac13
Post by Mac13 » Fri May 21, 2021 1:41 pm
Wow, some very strong opinions being expressed! Poor Ray Charles loved his Harley!
