Frame I.D
Frame I.D
Hello
Going to be listing this frame and other parts soon, but want to confirm frame model,I think it’s an sz
Frame number GS110XOO530827
Engine number GS110X-150339
Thanks very much for your time
- Has thanked: 118 times
- Been thanked: 256 times
Re: Frame I.D
Looks like an SZ from the front engine mounting point.
Does it have any documents? V5 etc.
What sort of price are you thinking of?
Out of curiosity only……
…….obviously
…….obviously
Re: Frame I.D
Sorry should have mentioned I have v5
Declared manufactured 1982
Date first reg in U.K. 1989
It came with kph clocks but unsure if there the original ones
Like yourself I thought of front engine mounts,just want to double check
Obviously
Thanks for your input
- Been thanked: 714 times
Re: Frame I.D
Indeed,the engine is also black Would the paint come of like this if it was factory black or is it a silver engine painted black (if that makes sense), again thanks for input
Re: Frame I.D
That engine has been painted aftermarket,its the wrong colour and type. Ultimately it dosen't really matter 40 years on , its going get blasted and recoated eitherway I'd have thought.
Re: Frame I.D
Very true,just thought I throw it into the mix
Ok I’m gonna say it’s an sz then,I’ll try and put an add together that makes sense
Thanks for all your input and time
Cheers steve
Re: Frame I.D
frame is SZ.
frame is also bent on the right side footpeg carrier. they almost always bend where the rear brake pivot is welded into the lower tube. its visibly bent in the pic. the lower tube should be straight but the forces of braking bend the tube in time.
Re: Frame I.D
Thanks for that,I see what you mean,hope it doesn’t put people off
