Carb woes.....again
- sparki
- Committee Member
- Has thanked: 80 times
- Been thanked: 72 times
Re: Carb woes.....again
the vent hoses need to be open and can hang if you want... if they're facing upwards then thats fine too... they're not fussy
I kept asking you if you wanted to borrow it...............and you never said you did, or wanted me to send it!.......... I guess that's not the case now , and you'd also like to borrow the Carb balancers too?
If Yes please say Yes and PM me...... and I will send them to you!
- sparki
- Committee Member
mick says he got the CD with info on it..... if it's the same cd as the one i got off katana central then it has the manual in jpg format on it?
- sparki
- Committee Member
i have a cd for the 750 and the japanese was only part of it..... if you want to PM me your address i can send you a copy.... or i can zip up the various sections and email em to you... they're quite large in their various sections though... if you have a half decent connection then i can always do that if it helps?
- Pedda
- Has thanked: 53 times
- Been thanked: 198 times
Give it some bigger pilots. That should sort it. You must not buy new ones, but use special taper reamers for jets.
- Katgeezer
- Has thanked: 6 times
- Been thanked: 8 times
I didn't think 'arris pipes made any difference to the jetting (but I might be wrong).
Also, 3 1/2 turns sounds a bit much, more like 2 1/2....
Just spoke to my mate who has a 750 and his screws are 2 turns out, no jet changes for idle with a Harris.
Hope that Helps. I have a reserve tank for carb setup if you need to borrow it.
GSX1100SZ
RD500LC
RD250LC
VF1000R
KE 125 1976
KOCUK 316
RD500LC
RD250LC
VF1000R
KE 125 1976
KOCUK 316
That would depend on if it has race or road bafflesKatgeezer wrote:I didn't think 'arris pipes made any difference to the jetting (but I might be wrong).
KOCUK 046 Jez
to be continued
to be continued
superfly
if you don't have a reserve tank, just get some flexible pipe and connector hose and get your original tank a lovely chair beside your bike
you will get flexible pipe and connector hose in your local motor factor.
