Carb woes!
Re: Carb woes!
Post by johnr » Sat Mar 10, 2018 10:05 pm
i think the black is a non stick coating to allow the slides to freely move up and down. as for cleaning it off, id be tempted to remove any loose flakes but not go too far to town on removing it all.
Re: Carb woes!
Post by PaulD » Sun Mar 11, 2018 7:44 am
johnr wrote:i think the black is a non stick coating to allow the slides to freely move up and down. as for cleaning it off, id be tempted to remove any loose flakes but not go too far to town on removing it all.
Thanks for the reply John, I thought it might be some sort of none stick and I’ve also done exactly what you said in just removing loose bits.
Cheers, PaulD
Re: Carb woes!
Post by johnr » Sun Mar 11, 2018 12:19 pm
thinking about it, the coating is more likely to reduce wear on the carb bodies and slides than it is to help them slide shut better.
Re: Carb woes!
Post by PaulD » Sun Mar 11, 2018 12:20 pm
Well it looks like I’ve sorted my carb problems :) I bolted everything up this morning and she fired up and ran a treat. It even needed choke to start which is summat it’s never done since I’ve owned it! A quick blast to check everything was ok and apart from needing to turn the tickover down after I had turned it up when I started it from cold she ran like a clock. Just got to do an oil & filter change now and we’re ready for the good weather 8-)
Been thanked: 714 times
Re: Carb woes!
Post by fossie » Sun Mar 11, 2018 3:08 pm
This is indeed really good news, a lesson in patience and glad the what looked like to some an expensive tool proved worth while.
Excellent.
pop-up
Has thanked: 10 times
Been thanked: 57 times
Re: Carb woes!
Post by pop-up » Sun Mar 11, 2018 3:13 pm
Good job there. Time now to enjoy.
