lower crankcase damage
spondonchris
Has thanked: 18 times
Been thanked: 18 times
Post by spondonchris » Thu Feb 06, 2014 6:15 pm
Hi, anyone know the best way to repair crankcases with a chunk missing? The lower crankcase on my 1100 project has a chunk missing just at the bottom of the ignition side as it has clearly been dropped at some point. I would say the missing part must be the size of a 10p approx.
Do I bend some ali and try and find a welder that can weld it in and dress it up? or do I buy a bottom crankcase, although from memory you have to buy pairs as I think they may be line bored?
Any ideas please
KOC397
Re: lower crankcase damage
Post by bobster » Thu Feb 06, 2014 6:54 pm
There's some DIY stuff called Lumi weld...............Google it!
Or take it to a local engineering/ fabrication firm and get them tAlloy weld /fill / repair it then just dress it with file, dremmel ,etc.........Make sure the electrics arnt connected or they can blow with the High voltage used on TIG welding.
Post by johnr » Thu Feb 06, 2014 7:05 pm
chemical metal. its not a stressed area and not full of oil, just chemical metal and smooth it off before you paint it.
spondonchris
Post by spondonchris » Thu Feb 06, 2014 9:44 pm
Thanks Bobster and Johnr. Wasn,t sure if a build up of weld might distort the cases? I had my efe cases welded a few years ago near to the clutch cover and it distorted the clutch gasket surface. Is there a way of not doing this?
Never used chemical weld, Is it easy to shape?
KOC397
Post by fossie » Thu Feb 06, 2014 10:12 pm
Even I have used chemical metal successfully!
spondonchris
Post by spondonchris » Thu Feb 06, 2014 10:17 pm
fossie wrote:Even I have used chemical metal successfully!
:lol: :lol:
KOC397
Post by johnr » Sun Feb 09, 2014 6:16 pm
its just a 2 part epoxy. make sure everythings clean first. follow the instructions on the pack. dont fret too much, you can smooth it off with wet and dry afterwards!
lomsavage
Has thanked: 3 times
Been thanked: 28 times
Post by lomsavage » Sun Feb 09, 2014 8:14 pm
i know of very good ally welder in manchester if you want to do it properly,
he did some crankcase and block(fin) repairs for me, very reasonable too
Hello from H
spondonchris
Post by spondonchris » Mon Feb 10, 2014 5:54 pm
Thanks H, if you can message me his details I will have a chat with him and make a call which way to go. Thanks for your help
KOC397
lomsavage
Post by lomsavage » Tue Feb 11, 2014 9:57 am
kickstart motorcycles.
86 Hewitt Street
Manchester
M15 4GB
0161 236 2777
Hello from H
