footpegs
- BigLT
- Has thanked: 1 time
- Been thanked: 3 times
footpegs
I want to fit alloy footpegs instead of the meaty rubber standard ones.
Does anyone know what ones from other bikes will fit? I think the 'gap' needs to be about 13mm
Liam
Liam
- Pedda
- Has thanked: 53 times
- Been thanked: 198 times
Re: footpegs
There are later Kat models with nicer pegs. Dunno which years, but I bet somebody will...
Ash
Re: footpegs
One of my Kats has alloy pegs without any rubber on the them, they are really slippy and when I get chance will be changing them for some with a bit of rubber on top.
- BigLT
Re: footpegs
Point taken about slipperiness, but do you know what bike those pegs were initially intended for? I was hoping for one of those useful conveniences, like zx6 sprockets fitting.
thanks
Liam
thanks
Liam
Re: footpegs
the sd ones have ally bodies with small rubber grips on top. they will fit onto your mounts.
- BigLT
Re: footpegs
Thanks John, I will have a look at the sd ones, but I really want to go for a more racey look. I have alloy pegs on my other bike and that's a lot quicker than my kat will be, so I'm used to them. I know I'm a tart before you say anything...
Re: footpegs
this it the same type as the sd, ok these are on a 250, but the sd pegs look the same,
http://www.bikez.com/pictures/browse.ph ... 9&pageno=3" onclick="window.open(this.href);return false;
Ash
Re: footpegs
My other Kat had the big fat rubber pegs and I changed those for the later SD (I think) versions which were a straight swap.
