lomsavage
- Has thanked: 3 times
- Been thanked: 28 times
Post
by lomsavage » Thu May 02, 2013 3:19 pm
how the hell do you get these things out, wont come off bracket because of speedo drive and although i've taken the screws out it doesn't seem to want to come off the clock assembly
or are they "idiot lights" cause i'm missing the obvious ???
cheers H
and yes it does mean i'm actually doing some work on a kat !!!!!
Hello from H
- Has thanked: 53 times
- Been thanked: 198 times
Post
by Pedda » Thu May 02, 2013 7:15 pm
You'll have to take nearly the whole speedo apart to get to those bulbs.
Once you removed the nuts 'n' bolts which hold the speedo drive gear you can tear it off and you will be able to get the bracket off.
lomsavage
Post
by lomsavage » Thu May 02, 2013 7:20 pm
Is it just the two screws for the speedo drive and "brute force" or am I missing something
Hello from H
Post
by Pedda » Thu May 02, 2013 7:44 pm
Just two screws, yes.
lomsavage
Post
by lomsavage » Thu May 02, 2013 7:56 pm
So do I have to be "really rough" and just pull speedo drive off
Hello from H
Post
by Pedda » Thu May 02, 2013 8:03 pm
YES DO IT!!!!
lomsavage
Post
by lomsavage » Thu May 02, 2013 8:09 pm
Cheers mate
Hello from H
Post
by johnr » Thu May 02, 2013 8:27 pm
remove the trip meter knob first,,,,
FBJ
- Has thanked: 5 times
- Been thanked: 31 times
Post
by FBJ » Thu May 02, 2013 8:58 pm
Dont be rough youll fec it
lomsavage
Post
by lomsavage » Sun May 05, 2013 2:30 pm
Trip knob removed so I could take main cover off
Now I'm inside clocks
Is speedo drive just "pull off" main clock body or is it twist and go
Seems pretty stuck to main clock assembly, is it just age or something else ?
Hello from H
